HAL.Port.OpticCfgCflct
Description
An optic module of a particular type has been inserted into a port which is not configured correctly for it.
Remedy
Change the configuration of the port to be correct for the optic module, or remove the optic module from the port and replace it with one for which the port is correctly configured.
Severity
Warning
Message Text
The configuration for the %optic% optic module is not correct - please configure port %slotPort% for auto-negotiation %autoNeg% and speed %speed%
Message Parameters
Name Type
optic String
slotPort SlotPort
autoNeg String
speed uInt
Applicable Platforms
